Thread: Copy one block reference to the same database
    2015-04
    16
    Default Copy one block reference to the same database
    Hi,
    I open a side database, then read the Model space block table record, then find the required block reference by name. So far I'm ok. Now I want to paste the same block reference at predefined insertion points n number of times. How can I accomplish this?
    6,420
    Default Re: Copy one block reference to the same database
    I see you already got your answer at the swamp.
    LinkedIn
  1. Match Multi-View Block to a Block Reference
    By tra1133 in forum AutoCAD General
    Last Post: 2012-08-28, 09:19 PM
  2. Replies: 0
    Last Post: 2011-10-11, 08:38 AM
  3. Revit MEP 2011 - Copy with Reference to Other Elements
    By gneuhaus in forum Revit MEP - General
    Last Post: 2010-08-27, 03:25 PM
  4. Reference lines - copy and rotate
    By mmiles in forum Revit Architecture - General
    Last Post: 2009-08-25, 03:39 PM
  5. (Copy of Post) Reference Line issues
    By Steve_Stafford in forum Revit Architecture - General
    Last Post: 2003-07-25, 11:18 PM
