Thread: Shared parameters error when loading a family
    2007-04
    3
    Default Shared parameters error when loading a family
    I got this error message when trying to load this manufacturer's family into a project. The family loads into a new project without any problem. I've tried auditing both the project and family. I also tried remapping the shared parameters to both the project and family. Does anyone have any other suggestions?
    2015-11
    Madison, WI
    1,318
    Default Re: Shared parameters error when loading a family
    The Shared parameter GUID matches a parameter with a different name. There is a conflict between the two, and you're lucky it didn't corrupt your project file. The best thing that you can do is delete the parameter from that family, if you wish to still use it with your project.
    This is one of the reasons why I strongly suggest to people not to download content from the web, unless it is coming from a trusted source.
    Cheers,
    Jeff S.
    All AUGI, all the time JoelLondenberg's Avatar
    2015-10
    508
    Quote Originally Posted by jsteinhauer View Post
    The Shared parameter GUID matches a parameter with a different name...
    From the image it looks like the same name, someone manually editing a shared parameter file is likely.
    ...The best thing that you can do is delete the parameter from that family, if you wish to still use it with your project.
    This is one of the reasons why I strongly suggest to people not to download content from the web, unless it is coming from a trusted source...
    Yes to both these comments.
  1. 2015: Loading shared parameters
    By sragan in forum Revit - API
    Last Post: 2014-12-22, 06:31 PM
  2. Loading Shared Parameters.
    By sean.darnell in forum Revit Architecture - Tips & Tricks
    Last Post: 2012-01-05, 02:42 PM
  3. Family parameters into shared
    By mmiles in forum Revit Architecture - General
    Last Post: 2008-12-16, 09:01 PM
  4. Shared parameters file loading
    By sifuentes in forum Revit Architecture - General
    Last Post: 2005-02-04, 04:20 PM
  5. Shared parameters in a window family not showing up...
    By christo4robin in forum Revit Architecture - General
    Last Post: 2003-07-03, 07:31 AM
