I have no problem with routines finding overlapping entities, but I like to be given the opportunity to choose what to do with them.
This works a little differently than your functional specification.
It checks the active layout to see if there are any overlapping text.
It creates a previous selection set with any duplicate text entities and tells you how many it found.
You can decide what to do with them.
P=
;______________________________________________________________________________________________________________
; Overlaptext finds and creates a selection set of overlapping text entities
; Written by: Peter Jamtgaard copyright 2015
(defun C:OverLapText (/ lstSelections lstOfSublists lstOverlaps lstSublist1 lstSublist2 ssSelections strHandle)
(if (setq ssSelections (ssget "x" (list (cons 0 "text")(cons 410 (getvar "ctab")))))
(and
(setq lstSelections (SelectionSetToList ssSelections))
(setq lstSelections (mapcar 'vlax-ename->vla-object lstSelections))
(setq lstOfSublists (mapcar 'PropertyMatchList lstSelections))
(foreach lstSublist1 lstOfSublists
(setq lstOfSublists (vl-remove lstSublist1 lstOfSublists))
(foreach lstSublist2 lstOfSublists
(and (/= (car lstSublist1)(car lstSublist2))
(apply 'and (mapcar 'equal (cdr lstSublist1)(cdr lstSublist2)))
(setq strHandle2 (car lstSublist2))
(not (member strHandle2 lstOverlaps))
(setq lstOverlaps (cons strHandle2 lstOverlaps))
(if lstOverlaps
(progn
(listtoselectionset (mapcar 'handent lstOverlaps))
(princ (strcat "\n" (itoa (sslength (ssget "p")))))
(princ " pieces of Overlapping text are in previous selection set! ")
(prin1)
; Convert a list of entities to a selection set
(defun ListToSelectionSet (lstENames / entItem ssSelections)
(setq ssSelections (ssadd))
(foreach entItem lstENames (ssadd entItem ssSelections))
(command "select" ssSelections "")
; Convert a selection set to a list of entities
(defun SelectionSetToList (ssSelections / entSelection intCount objSelection lstReturn)
(repeat (setq intCount (sslength ssSelections))
(setq intCount (1- intCount))
(setq entSelection (ssname ssSelections intCount))
(setq lstReturn (cons entSelection lstReturn))
lstReturn
; Function to create a list of properties for a vla-object
(defun PropertyMatchList (objSelection)
(mapcar '(lambda (x)(vlax-get objSelection X))
(list 'handle 'textstring 'insertionpoint 'layer 'height 'stylename); <- This is where you can change the properties
(vl-load-com)
