Hello everyone.
I work for a production home builder so some of my criteria and workflow may be different than what some of you are used to but I think this issue may transcend industries. I'm hoping this is a simple fix with some setting I've simply missed. I have been asked to correct an issue on our standard plans where our calculated areas for flooring is off. We have schedules on every house that show various rooms and their associated flooring type (i.e. carpet, tile, hardwood etc and this changes constantly) the areas are then sub-totaled. We have found this subtotal to be off significantly in some cases and have traced it back to the areas under the doors. Currently we use the information generated by the identity data in the room's properties for these schedules (room name and floor finish). Our room boundaries themselves are calculated up to the finished face of the wall. This is where the problem begins as the area under the door does not get included in the calculation. Simply changing the wall to calculate from its center also yields inaccurate information. I have checked the room heights and my rooms go from the top of my sub-floor to the underside of the ceiling so the room is completely enclosed. Is it a simple setting? perhaps the door family is flawed? any ideas or insight would be wonderful.
