Thread: Revit Schedules for Code Calculations
    2015-10
    Default Revit Schedules for Code Calculations
    I have created a new Revit Schedule that allows me to generate area and height calculations from table 503 in the IBC. It bases everything off of an gross building area plan that you create and can use different areas as different buildings. The only problem I'm running into so far is getting it to report back the UL or NP for the area or height. It always comes back inconsistent units. I know this is because they are looking for numbers and are area calculations and height calculations. Does anyone know of a work around for this though?
    Any help would be appreciated.
    Walt
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: Revit Schedules for Code Calculations
    UL and NP are based on Construction Type, so Area Plans in Revit cannot ( as far as I know ) include this.
    2009-11
    380
    Create a calculated value parameter set to number and make the formula: area/1 or height/1. This will make it a number, then you can use the converted number parameter in formulas.
  1. Link electrical panel schedules and calculations
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-11-13, 07:22 PM
  2. Code Calculations
    By cberteaux371801 in forum BIM Management - General
    Last Post: 2014-05-06, 02:13 PM
  3. Schedules - Calculations on Totals?
    By saeborne in forum Revit Architecture - General
    Last Post: 2008-11-17, 09:39 PM
  4. Total area parameter (schedules & BOMA calculations)
    By krista.manna in forum Revit Architecture - General
    Last Post: 2007-07-10, 08:28 PM
  5. Schedules: Remove gap, calculations
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2004-01-29, 06:28 AM
