Results 1 to 1 of 1
Thread: Layer Manager & Layer drop down are slow to open.
    2001-05
    Austin, TX USA
    2,201
    Default Layer Manager & Layer drop down are slow to open.
    The most common reason for this are layer filters. Layer Filter, though useful, can multiply very quickly. This also causes the drawing to have a larger file size.
    So to fix this problem you need to delete all the Layer Filters you don't need. This can take awhile if you have a few thousand filters. AutoLISP to the rescue. Our own Robert Bell wrote a routine just for this problem. See the attached file.
    Links:
    Autodesk Knowledge Base:
    ID: TS74735 - Layer filters propagate when object is copied from one drawing to another
    ID: TS84736 - Layer Manager takes long time to load compared to previous release
    ID: TS74036 - Layer Properties Manager loads slowly
    AUGI Forums:
    Layer Manger very slow ...
    Slow Layer Manager and Layer Pulldown
    Layer Manager slow to open
    Slow Layer Prop drop down list
    Slow Layers
    Need Help Deleting "Named Layer Filters"
    Layer Manager
    layer properties manager
    Are junk layer filters added?
    Delayed Layer Properties Manager
    LAYER CONTROL
    LAYER MANAGER DELAY IN 2005 LT & LSP
    AutoCAD 2005-problems
    Invisible document
    Inherited illegal characters?
    Named Layer Filters
    Layer Filters
    Slow Layer Manager
    AutoCAD 2005 - Layer control window, deadly slow
    Drop down layer list takes FOREVER to drop!
    Layer Properties Manager slow to open completely
    Last edited by Mike.Perry; 2007-03-30 at 11:15 AM. Reason: Additional information added.
  1. Layer Properties Manager slow to open completely
    By perry_kostanich in forum AutoCAD General
    Last Post: 2008-07-22, 08:58 PM
  2. Open Layer Manager without a Layer selected
    By msjca in forum AutoCAD General
    Last Post: 2006-11-28, 05:23 PM
  3. Slow Layer Manager and Layer Pulldown
    By bskripac in forum AutoCAD General
    Last Post: 2005-02-18, 01:28 PM
  4. Layer Manager slow to open
    By saveland80861 in forum AutoCAD General
    Last Post: 2005-01-15, 11:37 PM
  5. Slow Layer Prop drop down list
    By glen353712 in forum AutoCAD General
    Last Post: 2004-11-08, 11:12 PM
