Results 1 to 7 of 7
Thread: Perspective Print Problem
    I could stop if I wanted to stuntmonkee's Avatar
    2004-03
    Phoenix Arizona
    429
    Default Perspective Print Problem
    Anyone else have this issue?
    I print a Perspective shaded View. . . .previews fine. . .but when it prints, it eliminates the black lines and only leave the shaded lines on a bottom corner of the view.
    View settings are hidden (not shaded) line with advanced models sun shading on. and when it eliminates the black lines, its doing it at a 45 deg angle at a corner.
    I have had this happen quite a few times, but its just now really starting to bother me.
    I hope this was clear enough, I could try scanning and posting an image, but not sure how well it would read. . .so ill try with out first, and if its too confusing then ill scan it in.
    Thanks
    Stunts
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Perspective Print Problem
    Is the view placed on a sheet & then printed? If not, try it.
    Autodesk Revit Developer
    2004-02
    Waltham
    468
    Mea culpa. Try version 8...
    2004-03
    Phoenix Arizona
    429
    yeah, the view is on a sheet
    2004-03
    Phoenix Arizona
    429
    heres an attachments of what the problem is. It's really odd that it happens in the same place on every sheet , If you look at the Perspective views on the bottom right side. . .its hard to see on the screen, but very clear in a print.
    kinda driving me nutz.
    2004-02
    Waltham
    468
    Note that only the thick lines are affected. So, try reducing the resolution or making them thin (turn off silhouettes, for example).
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Which pdf writer are you using.? If adobe try this edit the properties to high quality see attached image.
    Scott D. Brown, AIA
    BECK
  1. Ceiling Problem in Perspective View
    By brian.tucker.143546 in forum Revit Architecture - General
    Last Post: 2008-01-03, 05:52 PM
  2. Perspective graphic / shadow problem
    By mwagenbach in forum Revit Architecture - General
    Last Post: 2007-08-29, 01:55 PM
  3. DWF Print Problem
    By dsw98 in forum Revit Architecture - General
    Last Post: 2007-03-07, 07:52 PM
  4. How to print cropped region of a perspective view
    By gravelin in forum Revit Architecture - General
    Last Post: 2005-02-09, 01:21 PM
  5. Print perspective on revit 6
    By DGA in forum Revit Architecture - General
    Last Post: 2004-10-27, 05:11 PM
