Results 1 to 1 of 1
Thread: AB334-1V: Existing Buildings to BIM Buildings with Autodesk® ImageModeler™
    2012-11
    3,030
    Default AB334-1V: Existing Buildings to BIM Buildings with Autodesk® ImageModeler™
    Session: AB334-1V
    Title: Existing Buildings to BIM Buildings with Autodesk® ImageModeler™
    Instructor: Amy Fietkau
    Course Description: Did you know that images of a building can be used to create a 3D model? Well, it's true. Autodesk ImageModeler is a subscription-based application from Autodesk that allows you to do just that! In this class, we'll look at how images can be calibrated using points and measurements. Then we'll take the time to mass up a building from those points and import it into other applications for further use. If you do renovation work or need to model existing buildings for facilities management, this class is just what you're looking for.
  1. CP222-3: Analyze Geometry of Buildings Using the Autodesk Revit API
    Last Post: 2014-12-01, 02:01 AM
  2. New work to existing buildings and Demolition
    By stanmpd in forum ACA General
    Last Post: 2008-10-14, 05:34 AM
  3. new building link between 2 existing buildings
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-06-27, 05:24 PM
  4. Existing Buildings?
    By H-Angus in forum ACA General
    Last Post: 2006-06-27, 12:09 AM
