Results 1 to 1 of 1
Thread: CP419-2: Making a Mesh in AutoCAD® .NET API
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CP419-2: Making a Mesh in AutoCAD® .NET API
    Session: CP419-2
    Title: Making a Mesh in AutoCAD® .NET API
    Instructor: Gopinath Taget
    Course Description: In this class we will discuss using the AutoCAD API support for meshing via entities like SubDMesh, PolygonMesh, and PolyfaceMesh. We will cover the uses and capabilities of these entities in approximating the intended surface in terms of appearance, accuracy and ease of manipulation. We will also introduce the Boundary Representation (BREP) .NET API and demonstrate its support for approximation and meshing of surfaces and solids.
  1. CP419-3: iLogic™: Outside the Box – External Rules Management
    Last Post: 2015-08-07, 05:18 PM
  2. CP419-1: AutoLISP®: Kicking It Up a Notch
  3. Convert MESH to legacy POLYFACE MESH object
    By PytorOuspensky in forum AutoLISP
    Last Post: 2013-06-26, 02:04 AM
  4. 2013 - Create Mesh in Autocad
    By tace86152814 in forum ACA General
    Last Post: 2012-12-17, 07:13 PM
  5. 2013: Railing issue making a Mesh Panel Railing need help
    By billy007nh in forum Revit Architecture - General
    Last Post: 2012-07-02, 04:28 PM
