Results 1 to 1 of 1
Thread: CR327-1: How Lean Construction Tools Are Used with VDC and BIM
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CR327-1: How Lean Construction Tools Are Used with VDC and BIM
    Session: CR327-1
    Title: How Lean Construction Tools Are Used with VDC and BIM
    Instructors: John Mack with Charles Zuckerman
    Course Description: This class provides an introduction to Lean Construction methods. We will cover several Lean Construction tools that are useful for Virtual Design and Construction (VDC) and Building Information Modeling (BIM). We will also discuss behavior and culture changes that enable Lean Construction and demonstrate training materials that have been successfully used to train groups to work using Lean Construction philosophies. We will tie all this together with how Lean Construction helps when using VDC/BIM on a project and how using integrated project delivery can enhance the use of Lean Construction tools.
  1. CR231-3: Implementing Lean Project Delivery and Virtual Design and Construction
    By Autodesk University in forum Construction and Real Estate
    Last Post: 2015-08-07, 05:21 PM
  2. Session 7, Part A: Adopting Lean Process in BIM
    By RTC Events in forum Session 7
    Last Post: 2014-11-13, 11:09 PM
  3. MA11-4: Autodesk® Data Management 101: A Guide to Lean Thinking
    By Autodesk University in forum Manufacturing
    Last Post: 2013-04-17, 04:50 AM
  4. What makes a Revit file BIG / sluggish - Lean and mean?
    By Nic M. in forum Revit Architecture - General
    Last Post: 2004-02-11, 12:45 AM
