Results 1 to 1 of 1
Thread: DV427-1: Parametric Design Modeling with Autodesk® 3ds Max®
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default DV427-1: Parametric Design Modeling with Autodesk® 3ds Max®
    Session: DV427-1
    Title: Parametric Design Modeling with Autodesk® 3ds Max®
    Instructor: David Fano
    Course Description: This presentation will show how to use Autodesk 3ds Max modeling tools to build iterative parametric design systems. In this class, we will cover Autodesk 3ds Max geometry types (Editable Mesh, Poly, Patch and NURBS), combine modifiers to build complex systems, use wire parameters to quickly make geometric patterns, and provide an introduction to MAXScript. In this session, you will learn to reduce the amount of explicit modeling, and instead build flexible design systems so you can focus more effort on design.
  1. Replies: 0
    Last Post: 2015-08-07, 03:57 PM
  2. Replies: 0
    Last Post: 2014-12-01, 03:38 AM
  3. DV9210-2: Parametric Design Modeling with Autodesk 3ds Max
    By Autodesk University in forum Design Visualization
    Last Post: 2014-12-01, 03:16 AM
  4. MA301-1P: Top-Down Design with Autodesk Inventor Using Skeletal Modeling
    By Autodesk University in forum Manufacturing
    Last Post: 2013-05-06, 01:20 AM
  5. Geometric Modeling? Parametric Modeling? BIM?
    By burcugokcen in forum Software
    Last Post: 2007-10-25, 09:11 PM
