Results 1 to 1 of 1
Thread: DV318-1V: Who Turned the Lights Out? Lighting Analysis with Autodesk® Revit® MEP 2011 and 3ds Max® Design 2011
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default DV318-1V: Who Turned the Lights Out? Lighting Analysis with Autodesk® Revit® MEP 2011 and 3ds Max® Design 2011
    Session: DV318-1V
    Title: Who Turned the Lights Out? Lighting Analysis with Autodesk® Revit® MEP 2011 and 3ds Max® Design 2011
    Instructor: Eric Bogenschutz
    Course Description: In this class, multiple different lighting analysis procedures will be discussed. An overview of the new features of lighting calculations and analysis within Autodesk Revit MEP 2011 will be discussed, along with the use of the new Autodesk FBX® file LINK in Autodesk 3ds Max Design 2011 to run point-by-point lighting analysis from your Revit model. Gone are the days of duplicating work over and over in different software packages. We will also look at the creation of a new light fixture, choosing the correct light source type, and placing that light source in the correct location within your families to guarantee accurate results. Flip on the light bulb (I mean LED), and watch as the new possibilities of lighting analysis are demonstrated.
  1. Replies: 0
    Last Post: 2015-08-07, 05:35 PM
  2. ME419-1L: Maximizing Autodesk® Revit® MEP 2011 for Design Efficiency
    By Autodesk University in forum MEP Design and Engineering
  3. CP316-1: Presenting Your Analysis Data in Autodesk® Revit® Architecture 2011
    Last Post: 2015-08-07, 05:18 PM
  4. DV208-1: Daylight and Lighting Analysis With Autodesk 3ds Max Design 2010
    By Autodesk University in forum Design Visualization
    Last Post: 2014-12-01, 03:11 AM
  5. Revit 2011 to Max Design 2011 to Backburner
    By mbeham in forum 3ds Max - General
    Last Post: 2011-01-14, 11:47 PM
