Results 1 to 1 of 1
Thread: ME322-3V: What Is Autodesk® Revit® MEP and How Do I Get Started?
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default ME322-3V: What Is Autodesk® Revit® MEP and How Do I Get Started?
    Session: ME322-3V
    Title: What Is Autodesk® Revit® MEP and How Do I Get Started?
    Instructor: Jason Boehning
    Course Description: The goal of this class is to provide designers and engineers with the essential knowledge you need to begin using Autodesk Revit MEP. The class will help you understand what the software is designed to accomplish, as well as what makes up Revit MEP. You will learn about Revit elements, categories, families, views, and how everything is integrated to produce a model. We will also discuss how Revit MEP can be implemented in an office to begin projects right away. After this, more in-depth Revit MEP classes will make sense, and you will benefit from the material instead of getting bogged down in the small details. This class is designed for Revit MEP users that are new to Revit, and may have even taken a class on Revit, but still do not have a good understanding of the software.
  1. ME322-1L: AutoCAD®, Autodesk® Revit®, and Autodesk Navisworks® Juggling...
    By Autodesk University in forum MEP Design and Engineering
    Last Post: 2015-08-07, 05:35 PM
  2. ME322-2: Autodesk® Revit® MEP Templates: Solving MEP Implementation Hurdles
  3. PM21-2: Getting Started with Autodesk® Buzzsaw®
    By Autodesk University in forum Project Management
    Last Post: 2013-04-17, 04:41 AM
  4. AR23-1: Autodesk Revit Basics: Getting Started
    By Autodesk University in forum Building Design
    Last Post: 2013-03-30, 02:10 AM
  5. Getting Started with Autodesk Revit Architecture PDF
    By jsnyder.68308 in forum Revit Architecture - General
    Last Post: 2009-10-29, 04:22 AM
