Results 1 to 1 of 1
Thread: SE327-1: Effective Design of Structural Steel Using Autodesk® Revit® Structure 2011 and the RSA Extensions
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE327-1: Effective Design of Structural Steel Using Autodesk® Revit® Structure 2011 and the RSA Extensions
    Session: SE327-1
    Title: Effective Design of Structural Steel Using Autodesk® Revit® Structure 2011 and the RSA Extensions
    Instructor: David Odeh
    Course Description: In this class, we will explore the new Autodesk® Robot™ Structural Analysis (RSA) extensions for Revit Structure 2011, with particular emphasis on using the extensions to be productive in the design and analysis of steel framed floors. We will start with an overview of the RSA extensions and how they work with the Revit Structure analytical model. Next, we will review the features and functions of the RSA Composite Designer, Floor Vibration Analysis, and Column Designer extensions. Last, we will apply these new Revit extensions to some real-life example problems from steel framed buildings, illustrating how you can be more efficient in the design of such buildings by using this tool.
  1. SE327-2: 3D Detailing of Reinforced Concrete and Steel Connections with AutoCAD® Revit® Structure
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2015-08-07, 05:36 PM
  2. SE214-1: Autodesk Revit Structure: A New Approach to Structural Design Integration
    Last Post: 2014-12-01, 03:53 AM
  3. Replies: 0
    Last Post: 2014-12-01, 03:51 AM
  4. SE104-1: Maximize the Use of Autodesk Revit Structure Extensions
    Last Post: 2014-12-01, 03:49 AM
  5. Replies: 0
    Last Post: 2013-04-17, 04:21 AM
