Session: UT416-2L
Title: Rural Utility Services (RUS) and Autodesk® Utility Design: A New Way to Get up and Running Quickly!
Instructor: Jim Bower
Course Description: Configuring Autodesk Utility Design for the first time can seem like a daunting task. However, with the new RUS configuration you can be up and designing in no time. This class is designed to give you firsthand experience with the new RUS configuration for Autodesk Utility Design. Together we will explore the functionality available through this new tool, and what you will need to get up and running quickly. When you have completed this class, you will be able to lay out a design, run Autodesk Utility Design engineering calculations, and create a staking sheet with this exciting new tool from the Autodesk Consulting team.
