Thread: Architectural model is set above 0'-0" so the copy/monitored levels don't match the Arch levels
    2012-08
    13
    Default Architectural model is set above 0'-0" so the copy/monitored levels don't match the Arch levels
    Hi All,
    I am setting up a new structural project and when I linked in the arch model I found that Level 01 in the arch model is at 96'-0". So when I started copy/monitor for the levels, they didn't match.
    Here is what I though of:
    1. I though of simply relocating the project, which fixed the problem, but I am sure if this a correct approach.
    2. I tried acquiring the coordinates from the arch model but nothing changed.
    Please advice, what is the best practice to fix this issue?
    Thanks a lot.
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Architectural model is set above 0'-0" so the copy/monitored levels don't match the Arch levels
    Did you check if the arch model is using Project Base Point to Display 96'?
    If so, no shared coordinates are involve so just relocate your project.
    2012-08
    13
    Quote Originally Posted by dhurtubise View Post
    Yes you are right, the architectural base point is showing 96'-0".
    Can you please explain the other case? what if he didn't relocate his model?
    2005-07
    3,792
    You would then use Shared Coordinates. Shared would display site elevation(96') and project would display 0'
  1. 2013: Levels in linked arch model changed. Now what?
    By stevedav453315 in forum Revit MEP - General
    Last Post: 2014-03-20, 07:56 PM
  2. 2012: Importing Revit Arch model & levels
    By Damo in forum Revit MEP - General
    Last Post: 2012-03-07, 05:19 PM
  3. plans for Copy/Monitored levels
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2009-01-13, 06:14 PM
  4. Replies: 1
    Last Post: 2008-11-03, 12:01 PM
  5. switching the sys. variable "Elev" to match project levels
    By jgardner.79905 in forum VBA/COM Interop
    Last Post: 2006-04-20, 08:55 PM
Tags for this Thread
