Hi All,
I would like to relate two other questions on the door of my previous thread http://forums.augi.com/showthread.ph...d-when-flipped
1- I cannot manage to make autocad write down the door width parameter value on a door tag inside the block. In block editor I put an attribute, insert field to take distance value from parameter, but when i insert the block, I only get ### and it says "the object referenced by the field has been erased". (After block insertation, in "enhanced attribute editor" deleting ###s and inserting fields again it shows distance value)
2- Furthermore, I also would like to make door type to change according to door width value when i play with the width grip, eg;
if width parameter="80" then write "K1"
if it=90 then write "K2"
if it=100 then write "K3"
etc...
Any help will be highly appreciated
Thx in advance
Tolga
