Results 1 to 8 of 8
Thread: 'Copy' command locks up AutoCAD/Carlson
    2015-08
    5
    Default 'Copy' command locks up AutoCAD/Carlson
    I keep running into situations, in certain drawings, I believe, where I try to copy mtext and AutoCAD become unresponsive. Is anyone else experiencing/have experienced this? VERY FRUSTRATIN!
    2003-03
    Philadelphia, PA
    2,392
    Default Re: 'Copy' command locks up AutoCAD/Carlson
    What version of AutoCAD are you using?
    Any chance that you have a "full" CUIX file loaded as a partial CUIX, in addition to the main CUIX? If you have two (or more) CUIX files loaded that each have contextual ribbon tabs specified for the same action, that can cause AutoCAD to lock up. This was semi-frequently reported by users of AutoCAD Architecture, who wanted to have some of the content from the ACAD.cuix available, and loaded it as a partial CUIX file while leaving the ACA.cuix file as the main customization. Both have a contextual ribbon tab that gets triggered when MText is selected; having both trying to activate locks up AutoCAD.
    2015-08
    5
    Is there a way I can check for this? I have customized one CUI to nullify the F1 key. I'm guessing Carlson has a CUIX file that is similar to the ACAD.cuix?
    2015-08
    5
    By the way, I have exploded the mtext, and have the same problem
    2007-08
    Rockford, Illinois
    161
    Not sure I have a solution but there are alternative ways of copying. I take it you are issuing the Copy command and having the problem. What about using the clipboard (ctlC, ctrlV) or use grip copy?
    Cairo - no, not Illinois
    5,069
    What version & flavor of AutoCAD, and what version of Carlson? Full civil package for Carlson, or???
    And have you tried the intellicad version of Carlson?
    2015-08
    5
    I am running a full version of AutoCAD2015 with Carlson Survey 2015
    2015-08
    5
    Quote Originally Posted by duhvinci View Post
    I can copy in model space fine. It is when I am in paper space. Ctrl C causes the same problem. I think I have less trouble using the actual 'copy' command. Not familiar with grip copy, I am looking into it, and will let you know. Thanks
  1. automatic multiple command when creating a fillet like copy command
    Last Post: 2012-01-18, 06:25 PM
  2. USE MOVE,COPY,ROTATE,SCALE COMMAND IN ONE COMMAND
    By cadsoft in forum AutoCAD Tips & Tricks
    Last Post: 2011-03-14, 02:47 PM
  3. AutoCAD locks files
    By Sashaver in forum Networks
    Last Post: 2007-07-26, 10:57 PM
  4. Autocad Locks up when plotting
    By cbernier01 in forum AutoCAD Plotting
    Last Post: 2007-07-17, 09:30 PM
  5. AutoCAD 2005 set Copy command to single default option
    By john.forman in forum AutoCAD General
    Last Post: 2004-10-12, 04:03 PM
Tags for this Thread
