If no other entities interfere those lines, than try this :
(defun c:overlaplinesdist ( / unit chkoverlap collinear-p ss li1 li2 p1 p2 p3 p4 )
(defun unit ( v )
(mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v)
(defun chkoverlap ( li1 li2 / p1 p2 p3 p4 )
(setq p1 (cdr (assoc 10 (entget li1))) p2 (cdr (assoc 11 (entget li1))) p3 (cdr (assoc 10 (entget li2))) p4 (cdr (assoc 11 (entget li2))))
(if (and (= (sslength (ssget "_C" p1 p2)) 2) (or (equal (unit (mapcar '- p2 p1)) (unit (mapcar '- p4 p3)) 1e-6) (equal (unit (mapcar '- p2 p1)) (unit (mapcar '- p3 p4)) 1e-6)))
t
nil
(defun collinear-p ( p1 p p2 )
(equal (distance p1 p2) (+ (distance p1 p) (distance p p2)) 1e-6)
(prompt "\nSelect 2 lines that overlap each other...")
(setq ss (ssget '((0 . "LINE"))))
(while (or (not ss) (and ss (/= (sslength ss) 2)) (and ss (= (sslength ss) 2) (not (chkoverlap (ssname ss 0) (ssname ss 1)))))
(prompt "\nEmpty sel.set or selected more or less than 2 line entities or 2 selected lines don't overlap... Please select 2 overlapping lines again...")
(setq li1 (ssname ss 0) li2 (ssname ss 1))
(cond
( (and (collinear-p p3 p1 p4) (collinear-p p3 p2 p4))
(princ (rtos (distance p1 p2) 2 50))
(grdraw p1 p2 1 1)
( (and (collinear-p p1 p3 p2) (collinear-p p1 p4 p2))
(princ (rtos (distance p3 p4) 2 50))
(grdraw p3 p4 1 1)
( (and (collinear-p p3 p1 p4) (collinear-p p1 p3 p2))
(princ (rtos (distance p1 p3) 2 50))
(grdraw p1 p3 1 1)
( (and (collinear-p p3 p1 p4) (collinear-p p1 p4 p2))
(princ (rtos (distance p1 p4) 2 50))
(grdraw p1 p4 1 1)
( (and (collinear-p p3 p2 p4) (collinear-p p1 p3 p2))
(princ (rtos (distance p2 p3) 2 50))
(grdraw p2 p3 1 1)
( (and (collinear-p p3 p2 p4) (collinear-p p1 p4 p2))
(princ (rtos (distance p2 p4) 2 50))
(grdraw p2 p4 1 1)
(princ)
(defun c:old nil (c:overlaplinesdist))
HTH, M.R.
