Results 1 to 9 of 9
Thread: Create array within a boundary
    2011-09
    308
    Default Create array within a boundary
    Hi folks,
    I'm looking for a routine similar to superhatch that will:
    1. Let me select a block (by name or by selecting it on screen)
    2. Enter spacing for rows/columns
    3. Select a boundary (polyline, circle, spline, etc.) either by internal point or "select object"
    4. Fill that area with instances of that block at the desired spacing.
    Superhatch was my first thought, and it's close... but when you explode the hatch, you get lines and arcs and I need the individual blocks to remain intact so I can extract data from them.
    There are a few others out there (Supercopy, etc.) but none work quite properly for what I need.
    Advanced Array comes close but its has it's own issues (mostly because it was written in 2007):
    http://cadtips.cadalyst.com/content/filling
    1. There are times when the setting of values regarding display of hatches (or your row spacing) can cause this routine to fail because it can (I assume) come up against the "Hatch too dense to display" error.
    2. You cannot "select object(s)" to select the boundary, only "select internal point" which in large drawings can have issues.
    3. It's "finicky" about how you enter the row and column distances (sometimes it just doesn't "take")
    4. There is no undo "mark" (if that's what you call it) so if you need to undo, it steps through each block, one at a time, then the hatch elements... etc.
    Anyone know of anything? I'm coming up empty.
    Thanks in advance for your help. Following is the LSP and DCL for Advanced Array which should do exactly what I need but does not work well in 2014.
    LSP
    ;;;Cadalyst AutoLISP Solutions	July 2007	ALSPSOL0707.ZIP / ADARRAY.LSP 	(c) Tony Hotchkiss
    (defun err (s)
      (if (= s "Function cancelled")
        (princ "\nADARRAY - cancelled: ")
        (progn (princ "\nADARRAY - Error: ")
    	   (princ s)
    	   (terpri)
        ) ;_ progn
      ) ;_ end of if
      (resetting)
      (princ "SYSTEM VARIABLES have been reset\n")
      (princ)
    ) ;_ end of err
    (defun setv (systvar newval)
      (setq x (read (strcat systvar "1")))
      (set x (getvar systvar))
      (setvar systvar newval)
    ) ;_ end of setv
    (defun setting ()
      (setq oerr *error*)
      (setq *error* err)
      (setv "CMDECHO" 0)
      (setv "BLIPMODE" 0)
      (setv "OSMODE" 0)
      (setv "CLAYER" (getvar "CLAYER"))
    ) ;_ end of setting
    (defun rsetv (systvar)
      (setvar systvar (eval x))
    ) ;_ end of rsetv
    (defun resetting ()
      (rsetv "CMDECHO")
      (rsetv "BLIPMODE")
      (rsetv "OSMODE")
      (rsetv "CLAYER")
      (setq *error* oerr)
    ) ;_ end of resetting
    (defun adarray ()
      (vl-load-com)
      (setq	*thisdrawing* (vla-get-activedocument
    			(vlax-get-acad-object)
    		      ) ;_ end of vla-get-activedocument
    	*modelspace*  (vla-get-ModelSpace *thisdrawing*)
      ) ;_ end of setq
      (setq	bnameindex nil)
      (setq doit 4)
      (setq ad_id (load_dialog "adarray.dcl"))
      (while (>= doit 2)
        (if	(not (new_dialog "adarray" ad_id))
          (exit)
        ) ;_ end of if
        (init-array)
        (action_tile "bname" "(setq bnameindex (atoi $value))")
        (action_tile "row" "(setq *rowdist* (atof $value))")
        (action_tile "col" "(setq *coldist* (atof $value))")
        (action_tile "pick" "(done_dialog 3)")
        (action_tile
          "accept"
          "(get-adarray-data) (done_dialog 1)"
        ) ;_ end of action_tile
        (setq doit (start_dialog))
        (cond
          ((= doit 1)
           (do-array)
          ((= doit 3)
           (setq *point0* (getpoint "\nPick a point: "))
        ) ;_ end of cond
      ) ;_ end of while
      (unload_dialog ad_id)
    ) ;_ end-of adarray
    (defun init-array ()
      (setq	blks (vla-get-blocks *thisdrawing*)
    	num  (vla-get-Count blks)
    	*blknames* nil
    	i 1
      ) ;_ end of setq
      (repeat (- num 2)
        (setq blk	   (vla-item blks (setq i (1+ i)))
    	  bname	   (vla-get-Name blk)
    	  *blknames* (append *blknames* (list bname))
        ) ;_ end of setq
      ) ;_ end of repeat
      (if *blknames*
        (progn
          (start_list "bname")
          (mapcar 'add_list *blknames*)
          (end_list)
        ) ;_ end of progn
      ) ;_ end of if
      (if bnameindex
        (set_tile "bname" (itoa bnameindex))
      ) ;_ end of if
      (if *rowdist*
        (set_tile "row" (rtos *rowdist*))
        (set_tile "row" "2")
      ) ;_ end of if
      (if *coldist*
        (set_tile "col" (rtos *coldist*))
        (set_tile "col" "2")
      ) ;_ end of if
    ) ;_ end of init-array
    (defun get-adarray-data ()
      (setq bnameindex (atoi (get_tile "bname")))
      (setq *bname* (nth bnameindex *blknames*))
      (setq *rowdist* (atoi (get_tile "row")))
      (setq *coldist* (atoi (get_tile "col")))
    ) ;_ end-of get-tool-data
    (defun do-array ()
      (setq lyr "arr-hatch")
      (vl-cmdf "Layer" "M" lyr "C" "green" "" "")
      (vl-cmdf "-Hatch" *point0* "P" "U" "0.0" *rowdist* "N" "")
      (vl-cmdf "Explode" (entlast))
      (setq	ss     (ssget "X"
    		      (list '(0 . "LINE")
    			    (cons 8 lyr)
    		      ) ;_ end of list
    	       ) ;_ end of ssget
    	num    (sslength ss)
    	i      -1
      ) ;_ end of setq
      (rsetv "CLAYER")
      (repeat num
        (setq en (ssname ss (setq i (1+ i))))
        (vl-cmdf "Measure" en "B" *bname* "Y" *coldist*)
        (entdel en)
      ) ;_ end of repeat
    ) ;_ end of do-array
    (defun c:ad ()
      (setting)
      (adarray)
      (resetting)
      (princ)
    ) ;_ end of c:ad
    (prompt "\nCopyright (c) 2007, Tony Hotchkiss")
    (prompt "\nEnter AD to start")
    DCL
    // ADARRAY Dialogue Box - by Tony Hotchkiss 4/21/07
    adarray : dialog // advanced array data
       label = "ADAVANCED ARRAY";
          :column {
            :popup_list {
              label = "Block name     ";
              key = "bname";
              width = 8;
            }// popup list
            :edit_box {
              label = "Distance between rows:      ";
              key = "row";
              width = 8;
            }// edit box
            :edit_box {
              label = "Distance between columns:";
              key = "col";
              width = 8;
            }// edit box
            :spacer {}
            :spacer {}
            : retirement_button {
               key = "pick";
               label = "Pick point";
            }// retirement_button
           }// column
       ok_cancel;
       : text {
          label = "Copyright (c) 2007 Dr. A. Hotchkiss";
          alignment = left;
    } // adarray
    -JP
    2003-07
    561
    Default Re: Create array within a boundary
    There is a simple way to do it pick a lower left point upper right and a control point. Array your new infill block but make it larger than required in terms of number, then pick boundary as indicated and erase all outside of this boundary. I did this years ago for waffle slab panel design drawing squares on any shape from a known point just a couple of picks and all done trimmed back to the shape.
    Anyway here is the auto trim the hard bit
    (defun c:trpls ( / x pt2 obj obj2 co-ords)
    (setq oldsnap (getvar "osmode"))
    (setvar "osmode" 0)
    (setq x -1)
    (setq obj (car (entsel "\nPick cut line")))
    (setq pt2 (getpoint "pick offset direction"))
    (command "_offset" 1 obj pt2 "")
    (if (not co-ords2xy)(load "pline co-ords2"))
    (setq obj2 (entlast))
    (setq co-ords (getcoords obj2))
    (co-ords2xy) ; list of 2d points making pline
    (entdel obj2)
    (command "_TRIM" OBJ "" "F")
    (while (= (getvar "cmdactive") 1 )
    (repeat (length co-ordsxy)
    (command  (nth (setq x (+ x 1)) co-ordsxy))
    (command "")
    (setq co-ordsxy nil) ; for next time
    ; pline co-ords example
    ; By Alan H
    (defun getcoords (ent)
      (vlax-safearray->list
        (vlax-variant-value
          (vlax-get-property
        (vlax-ename->vla-object ent)
        "Coordinates"
    (defun co-ords2xy ()
    ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
    (setq len (length co-ords))
    (setq numb (/ len 2)) ; even and odd check required
    (setq I 0)
    (repeat numb
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
    ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
    (setq co-ordsxy (cons xy co-ordsxy))
    (setq I (+ I 2))
    ; program starts here
    (setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
    ;(co-ords2xy) ; list of 2d points making pline
    2011-09
    308
    OK, I've done some testing and uncovered this.
    If I change the bit of code in the LSP file that sets the values for Row distance, Column Distance and Block Name so that it is not pulling from the DCL values but instead is hard coded, it works great. So I assume its having trouble getting the values from the dialog box. My knowledge of DCL is even more lacking than my knowledge of LISP... Any help is appreciated.
    I may try to cobble together a routine without using DCL if I can.
    Original Code:
    Modified Code:
      (setq *bname* "Pro Perennial")
      (setq *rowdist* 48)
      (setq *coldist* 48)
    2011-09
    308
    Allright...
    I have cobbled (and I mean cobbled) this together and it almost works...
    Prompts for Row and Column distances (enter value or pick points)
    Prompts to select a block to use
    Prompts for an internal point
    It creates the array within the boundary as expected, but the blocks it inserts do not seem to have the attribute tag like the selected block does (see attached drawing).
    As always, any help is appreciated.
    (defun c:TESTadarray  (/ ent STR lyr ss rowdist coldist point0)
    (setq rowdist (getdist "\n Distance Between rows :"))
    (setq coldist (getdist "\n Distance Between columns :"))
         (cond
               ((and
                      (setq ent (car (entsel "\nSelect Block Entity: ")))
                      (eq (cdr (assoc 0 (entget ent))) "INSERT")
                      (setq STR (vla-get-effectivename
                                            (vlax-ename->vla-object ent)))
      (setq lyr "L-PL PERENNIAL")
      (vl-cmdf "Layer" "M" lyr "C" "yellow" "" "")
      (vl-cmdf "-Hatch" (getpoint "\nPick a point: ") "P" "U" "0.0" rowdist "N" "")
      (setq	ss     (ssget "X"
    		      (list '(0 . "LINE")
    			    (cons 8 lyr)
    		      ) ;_ end of list
    	       ) ;_ end of ssget
    	num    (sslength ss)
    	i      -1
      ) ;_ end of setq
      (repeat num
        (vl-cmdf "Measure" en "B" STR "Y" coldist)
        (entdel en)
      ) ;_ end of repeat
    2011-09
    308
    This seems to be an issue with the MEASURE command and blocks with attributes. Added the following line and seems to be working now. Still, I'm sure it could be cleaned up, error handling added, etc.
    (vl-cmdf "attsync" "Name" STR)
    2017-07
    Hi everyone,
    I am pretty new to Lisp and also new to this Forum.
    I am really excited about Lisp and really motivated to learn but the code above is beyond my knowledge.
    The Routine sounds like it would be perfect to safe me a lot of time but unfortunately its not working till now.
    When I pick the Block and I wand to pick a point I always get the error: bad Argument type: lselsetp Nil.
    Can you give me a hint where to find the Problem?
    Any help is appreciated!
    Best
    Simon
    2003-07
    561
    Jpcad here is a lisp that has a 1 2 or 3 dcl input its a library style routine so you load as required.
    ; Input  Dialog box with variable title
    ; multiple lines of dcl input supported
    ; add extra lines if required by copying code defun
    ; By Alan H 2015
    (vl-load-com)
    ; 1 line dcl
    ; sample code (ah:getval1 "Line 1" 5 4 "-")
    (defun AH:getval1 (title width limit def1 / fo fname)
    ; you can hard code a directory if you like for dcl file
    (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
    ;(setq fo (open (setq fname "c:\\acadtemp\\getval.dcl") "w"))
    (write-line "ddgetval : dialog {" fo)
    (write-line " : row {" fo)
    (write-line ": edit_box {" fo)
    (write-line (strcat "    key = "  (chr 34) "key1" (chr 34) ";") fo)
    (write-line  (strcat " label = "  (chr 34) title (chr 34) ";"  )   fo)
    ; these can be replaced with shorter value etc
    (write-line (strcat "     edit_width = " (rtos width 2 0) ";" ) fo)
    (write-line (strcat "     edit_limit = " (rtos limit 2 0) ";" ) fo)
    (write-line "   is_enabled = true;" fo)
    (write-line "    }" fo)
    (write-line "ok_only;}" fo)
    (close fo)
    (setq dcl_id (load_dialog  fname))
    ; pt is a list 2 numbs -1 -1 centre ('(20 20))
    ;(not (new_dialog "test" dch "" *screenpoint*))
    (if (not (new_dialog "ddgetval" dcl_id))
    (exit))
    (set_tile "key1" (setq val1 def1))
    (action_tile "key1" "(setq val1 $value)")
    (mode_tile "key1" 3)
    (start_dialog)
    (done_dialog)
    (unload_dialog dcl_id)
    ; returns the value of val1 as a string
    (vl-file-delete fname)
    ) ; defungetval1
    ; 2 line dcl
    ; sample code (ah:getval2 "Line 1" 5 4 "1" "Line2" 8 7 "2")
    (defun AH:getval2 (title1 width1 limit1 def1 title2 width2 limit2 def2 / fo fname)
    (write-line "ddgetval2 : dialog {" fo)
    (write-line " : column {" fo)
    (write-line  (strcat " label = "  (chr 34) title1 (chr 34) ";" ) fo)
    (write-line (strcat "     edit_width = " (rtos width1 2 0) ";" ) fo)
    (write-line (strcat "     edit_limit = " (rtos limit1 2 0) ";" ) fo)
    (write-line "   is_enabled = true ;" fo)
    (write-line "spacer_1 ;" fo)
    (write-line (strcat "    key = " (chr 34) "key2" (chr 34) ";") fo)
    (write-line (strcat " label = "  (chr 34) title2 (chr 34) ";"  ) fo)
    (write-line (strcat "     edit_width = " (rtos width2 2 0) ";" ) fo)
    (write-line (strcat "     edit_limit = " (rtos limit2 2 0) ";" ) fo)
    (close fo)
    ; code part
    (if (not (new_dialog "ddgetval2" dcl_id))
    (exit))
    (mode_tile "key2" 3)
    (set_tile "key2" (setq val2 def2))
    (action_tile "key2" "(setq val2 $value)")
    (start_dialog)
    (done_dialog)
    ; returns the value of val1 and val2 as strings
    ) ; defungetval2
    ; 3 line dcl
    ; sample code (ah:getval3 "Line 1" 5 4 "0.9" "Line 2" 8 7 "wow" "Line 3" 6 4 "123")
    (defun AH:getval3 (title1 width1 limit1 def1 title2 width2 limit2 def2 title3 width3 limit3 def3 / fo fname)
    (write-line "ddgetval3 : dialog {" fo)
    (write-line (strcat "    key = " (chr 34) "key3" (chr 34) ";") fo)
    (write-line (strcat " label = "  (chr 34) title3 (chr 34) ";"  ) fo)
    (write-line (strcat "     edit_width = " (rtos width3 2 0) ";" ) fo)
    (write-line (strcat "     edit_limit = " (rtos limit3 2 0) ";" ) fo)
    (close fo)
    ; code part
    (if (not (new_dialog "ddgetval3" dcl_id))
    (exit))
    (mode_tile "key3" 3)
    (set_tile "key3" (setq val3 def3))
    (action_tile "key3" "(setq val3 $value)")
    (start_dialog)
    (done_dialog)
    ; returns the value of val1 val2 and val3 as strings
    ) ; defungetval3
    (if (not ah:getval3)(load "getvals3"))
    (ah:getval3 "Enter horiz scale" 5 4 "100" "Enter vertical scale " 5 4 "50" "Decimals" 5 4 "2")
    (setq horiz (atof val1))
    (setq vert (atof val2))
    (setq prec (atof val3))
    2020-06
    Hi., please help me when using TESTADARRAY.LSP as below.
    Command: TESTADARRAY
    Distance Between rows :1000
    Distance Between columns :1000
    Select Block Entity: Layer
    Current layer: "L-PL PERENNIAL"
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: M
    Enter name for new layer (becomes the current layer) <L-PL PERENNIAL>: L-PL PERENNIAL Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: C
    New color [Truecolor/COlorbook] : yellow
    Enter name list of layer(s) for color 2 (yellow) <L-PL PERENNIAL>: Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:
    Command:
    Pick a point: -Hatch
    Current hatch pattern: _USER
    Specify internal point or [Properties/Select objects/draW boundary/remove Boundaries/Advanced/DRaw order/Origin/ANnotative/hatch COlor/LAyer/Transparency]: Selecting everything...
    Selecting everything visible...
    Analyzing the selected data...
    Analyzing internal islands...
    Specify internal point or [Properties/Select objects/draW boundary/remove Boundaries/Advanced/DRaw order/Origin/ANnotative/hatch COlor/LAyer/Transparency]: P
    Enter a pattern name or [?/Solid/User defined/Gradient] <User defined>: U
    Specify angle for crosshatch lines <0>: 0.0
    Specify spacing between the lines <1000.0000>: 1000
    Double hatch area? [Yes/No] <N>: N
    Command: Explode
    Select object:
    Hatch boundary associativity removed.
    Command: ; error: bad argument type: lselsetp nil
    2003-07
    561
    There is no code to look at, run the code in VLIDE, make sure under Debug have break on error turned on, then run when error occurs click last break source, this will hopefully highlite the line that is causing the error
  1. Replies: 6
    Last Post: 2014-09-20, 03:54 AM
  2. How to create a model line array in two directions
    By markthorleyadt768272 in forum Revit - Platform
    Last Post: 2012-10-10, 01:39 PM
  3. Create tight boundary around multiple objects
    By ccowgill in forum AutoLISP
    Last Post: 2008-10-24, 12:03 PM
  4. Create boundary in C#
    By humberto in forum Dot Net API
    Last Post: 2007-06-03, 08:26 AM
  5. Unable to create Boundary that contains Splines
    By steven.bryan in forum AutoCAD General
    Last Post: 2006-06-03, 12:46 PM
