Thread: use baluster per tread on stair (with no top rail?)
    2010-04
    140
    Default use baluster per tread on stair (with no top rail?)
    I am trying to create a stair railing system that has only Balusters and no top rail. I would like to use the "use baluster per tread on stair" and have two balusters per tread. but when I attempt this with no top rail the baluster is only a few inches tall. so I created a top rail profile using invisible lines and made the top rail really small. with this top rail it works but the top rail shows in every view even though it says its using invisible lines. could use some help. would like to not have the top rail if possible.
    2010-10
    Chicago, IL
    376
    Default Re: use baluster per tread on stair (with no top rail?)
    You can hide top rail subcategory in VG, or create a filter if you want to hide only some of them. Save the settings to your template. You can also, tab into the top rail and hide it by element (I’m not a big fan of hiding objects by element though).
    Or, select the rail (entire rail) -> edit type ->set top rail to none -> click OK -> with the rail still selected -> edit path -> select the path -> in the option bar, set height correction to custom and add a value.
  1. Sq Baluster - Rd Rail
    By jrostar in forum Revit Architecture - Families
    Last Post: 2010-10-06, 03:05 PM
  2. What controls the Baluster Per Tread spacing?
    Last Post: 2010-03-02, 05:30 PM
  3. Stair - extend baluster feet to tread?
    By ws in forum Revit Architecture - General
    Last Post: 2007-12-18, 08:30 PM
  4. Baluster to tread
    By trent59822 in forum Revit Architecture - General
    Last Post: 2005-10-10, 09:33 PM
  5. Baluster per tread?
    Last Post: 2005-07-12, 08:47 PM
