Results 1 to 6 of 6
Thread: Field in an Attribute not updating
    2005-09
    184
    Default Field in an Attribute not updating
    Hello, I have a dynamic block that I am trying to have a field update in an attribute. I cannot seem to get it to work. Currently this field is in only one attribute in the 4'-0" Extension Plate Face... visibility (If you look at my block). It's the last 2 numbers of the text (PS-P-824) where the 24 correlates to the length of the panel and should change when stretched.
    I have tried re-inserting the block into the file, w-blocking out the block and re-inserting it and attsync-ing the block.
    Am I missing a step ? thanks in advance
    2015-03
    40
    Default Re: Field in an Attribute not updating
    In place of using the line object length for your field, use the actual linear parameter value from the Block Placeholder fields
    2005-09
    184
    Hi, thanks for the reply. I had tried that, and unless I did something else wrong, that does not work. See image:
    2015-03
    40
    Try this it works for me
    2015-11
    France
    9
    Quote Originally Posted by derek.96018 View Post
    I don't know why it doesn't work, but you found the solution.
    Just try to delete the field in your attribute and insert another with "Long Panel Length" property.
    Then re-insert your block.
    It works for me.
    2005-09
    184
    Fantastic ! Thanks steven-g and Clem. Deleting the field in the attribute and placing a new one worked.
  1. 2013: Field within block not updating
    By montero1 in forum AutoCAD General
    Last Post: 2015-08-07, 02:13 PM
  2. DeviceName field is not updating in a block
    By jkad27 in forum AutoCAD Fields
    Last Post: 2012-02-28, 08:36 AM
  3. Field Attribute Not Updating on .NET Insert?
    By mcoffman in forum Dot Net API
    Last Post: 2011-06-17, 08:43 PM
  4. Field in Title Block not updating
    By Grumpy in forum AutoCAD Fields
    Last Post: 2005-02-22, 10:13 PM
Tags for this Thread
