Thread: Classic Layer Manager
    2015-10
    6
    Default Classic Layer Manager
    I am using ACA 2016 and the classic Layer Manager will not display, is there a way to run legacy or the classic layer manager in 2016?
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Classic Layer Manager
    The CLASSICLAYER command will always open the classic (modal) layer manager dialog. LAYERPALETTE will always open the modeless (palette) layer manager. You can control which version opens with the LAYER command by setting the value of the LAYERDLGMODE system variable: 0 will use the modal dialog and 1 will use the modeless palette.
  1. Type Letters to Jump to Layer Name in Layer Property Manager
    Last Post: 2016-01-19, 04:41 PM
  2. Replies: 11
    Last Post: 2009-02-27, 04:25 PM
  3. Replies: 3
    Last Post: 2007-10-16, 07:22 PM
  4. Ability to Update an XREF Layer from the Layer Properties Manager
    Last Post: 2007-05-08, 12:50 PM
  5. Replies: 1
    Last Post: 2006-04-03, 10:01 PM
