Thread: DIMENSIONS
    2015-09
    3
    Default DIMENSIONS
    hope I am in the correct place.
    Trying to get the dimension line to "not" break because the text is taking up the space... depending on the scale factor use the text may be larger or smaller the larger the text the chances are greater that the dimension line will break.
    "WE" the company owner and myself are always adding lines to correct this problem. Its an extra step that I would like not to do.
    Please see attachment
    Thanks
    MikeC
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    441
    Default Re: DIMENSIONS
    Playing around a little, I found that the "Fit" setting for Text Movement affected whether or not the line would break when the text was moved. If it's set to "Move text, no leader", then the dimension line breaks, but the dimension line stays when it's set to "Move text, add leader".
    Looking at your image, what are the property differences between the 7'-2" dimension and the 6'-5" dimension?
    2015-09
    3
    ok, I will agree with that statement
    thanks...
    but I also have dimensions that are at the home positions, have not move them, and when the annotative scale is change the break appears again...
    placing a dimension of 3'-4" for example and a scale factor of 1/8 or smaller the dimension line breaks
    I have to draw a line over the dimensions to get it to look correct
  1. Convert Aligned Dimensions to Rotated Dimensions
    By CADdancer in forum AutoLISP
    Last Post: 2016-03-15, 12:22 PM
  2. Aligned dimensions acting like linear dimensions (only up-down, left-right on page as viewed)
    By browns.joseph308864 in forum Revit Architecture - General
    Last Post: 2011-12-07, 01:48 AM
  3. Calculate Alternate Dimensions Based on Overridden Dimensions
    Last Post: 2007-09-18, 02:01 PM
  4. Replies: 3
    Last Post: 2006-09-20, 05:14 AM
