I have a roof above a garage at the first level of a house and this garage has a dormer (of sorts). the problem is, the roof slopes towards the second level walls of the house but stops below the level of the peak of the dormer. I can't use the dormer tool for this reason, and I've tried also making an extruded roof and joining them - which works, but leaves me the extruded roof geometry INSIDE the garage/house, so then in sections it would just be awful modelling. I also need the main roof to have a somewhat decorative soffit extending into the dormer wall elevation and the way I've done it currently I can't get that result.
I also have a second problem with the main roof. Between the large dormers on the main roof the roof has a notch. the overhang for the whole roof is 12" and there should be a gutter all around the front and the sides of the notch. However, due to the nature of revit footprint roofs, that notch then has a slightly higher eave height than the front of the roof and I can't put the gutter on the sides that return in to the notch.
If that makes no sense, check out the attachments.
(all in all, I think they've fudged the CAD file to make it look nice, and I am not sure if it is actually possible to build - I would appreciate the opinion of someone with more residential experience on that one)
So, I'm lost. I'm no roof expert, however I've been learning rapidly while trying to cobble together this roof for a client and it's quite amazing what you can manipulate.
I've attached a CAD file of what I need the roofs to look like, as well as a basic revit model of what I have so far as the roof goes. (The revit file is in a .zip file)
