Summary: Specify break with point or similar for lofted flange
Description: Unless you create a break with a start and end point Inventor cannot unfold a lofted flange correctly. Please add feature where by you could input a point or similar, that would create the gap required, plus input how wide the gap is, which would create the gap so that inventor can create the correct flat pattern. So if ie one side of a lofted flange was a closed circle be inputting the break point it would act as though the circle was an arc.
Product and Feature: Inventor - Sheet Metal
Submitted By: William Marshall on 10/01/2015
