mmiles
Thanks, Tom.
FWIW I was using LAS to establish the layers I wanted (kind of as a "working" or "setup" stage), and did leave the "layer snapshot" checked when making views. I am still learning how to use both Layer States and Views, and I think there are times when the two are working against one another (in Viewports placed on sheet layouts). Knowing me, I am overthinking it...and gotten myself confused.
Unchecking "turn layers off not found in layer state" did the trick. I'll have to think more about that setting as I get deeper into the project.
I added the following lines to my acaddoc.lsp file to uncheck "turn layers off not found in layer state" each time I open a drawing:
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\<<C3D_Imperial>>\\Dialogs\\AcLayerApps:LayerStatesManager") "LayerNotFound" "0")
; Layer States Manager - Do not turn off layers not found in layer state
Sadly AutoCAD does not save these settings.
