Results 1 to 7 of 7
Thread: Matchline Stationing using fields
    2015-10
    73
    Default Matchline Stationing using fields
    Is there a way to put a field in a matchline text string that would place the start station on one side of the sheet and the end station on the other? I have 20,000 lf of sheets to label and that's without the route changes that are sure to come. Any help is GREATLY appreciated. I'm attaching an image file for clarification.
    Rq
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Matchline Stationing using fields
    Fields do not work with Civil 3D objects.
    2015-10
    73
    I must be missing something somehow. I'm able to get the title of every sheet to generate the stationing spread for each individual sheet using fields. Sometimes I create 20 sheets using the Plan and Production tab, and the stationing is placed in the title using fields that reference the SSM.
    There must be a way to grab the stationing somehow, my worry is that I've been looking at this so hard for so long that I'm overlooking the obvious. Maybe its a function that's best handled by a diesel or lisp expression, which, by the by I have no knowledge on.
    2002-01
    jUSt Here (a lot)
    9,106
    The plan production tools does that automation for you in the sheet set manager. Thus, the field is referencing the sheet set manager, which was set by that tool. Unfortunately, Civil 3D object properties are not available as fields.
    2015-10
    73
    Awesome!! Wish there was a way to create user defined fields.......Ok so now for some crazy-funky work around, probably involving SSM and custom properties. Wish me luck.
    Thank you, Opie
    Rq
    2002-01
    jUSt Here (a lot)
    9,106
    Custom Sheet Fields would work. It's just a manual process. To automate it, you would need to go with a .NET solution as SSM is not exposed to AutoLISP.
    2015-10
    73
    That will definitely be easier than going to each individual sheet and editing 2 text strings per sheet and I'll have the stationing spread in the properties box to go by. Should reduce error.
    Thanks again Opie
  1. Stationing
    By blaze348142 in forum AutoLISP
    Last Post: 2013-04-28, 08:48 PM
  2. 2012: Stationing in segments rather than cumulative
    By PGP-LA in forum AutoCAD Civil 3D - Profiles
    Last Post: 2013-01-22, 04:11 PM
  3. Stationing labels
    By robertlynch in forum AutoCAD LT - General
    Last Post: 2010-03-09, 03:30 PM
  4. Expressions for stationing
    By mhs50000 in forum AutoCAD Map 3D - General
    Last Post: 2007-10-29, 02:46 PM
