Hi everybody.
So, I've created a script in Dynamo that will allow me to link a VAV box (or any mechanical equipment) to an HVAC Zone, so that if the VAV's Mark parameter changes, the HVAC Zone's Name will update. I've already created a similar script for Thermostats that works. My problem isn't with Dynamo.
My problem is that there's an HVAC Zone called "Default" that's set to Read Only. Because I can't write to this one Zone's Name Parameter, my entire Dynamo script is failing. (Dynamo can only write to an entire Category, Family, or Type. Unfortunately, there's no way to get it to conditionally select something.)
Can anyone tell me why this Default Zone exists? And is there something I can do about this?
Thanks for reading!
