Thread: Print All Layouts in one single pdf
    2015-11
    Default Print All Layouts in one single pdf
    Hi
    can anyone tell me how to Print All Layouts in one single pdf in AutoCad 2006..its urgent ..thankx
    Earth
    9,805
    Default Re: Print All Layouts in one single pdf
    I suspect the crickets are because 2006 was 10 versions ago and not too many people have access to this.
    I don't ever remember if 2006 had the PUBLISH command yet.
    I went over to http://www.hyperpics.com/commands/index.asp to check it out and Yes, 2006 did have the publish command.
    Now all you need is a PDF print driver.
    I think 2007 was the first version to come with DWG to PDF.PC3 and it was horrendous.
    So get a PDF print driver (CutePDF....? ) and then use the PUBLISH command. Make sure to set the settings in the PDF driver so that it will create one, multipage PDF.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,719
    Back when I worked in 2006, we would first publish to multi-sheet DWF, and then print that to PDF.
    PUBLISHCOLLATE sysvar wasn't introduced until 2009.
    HTH
    Computer Specs:
  1. Single mouse click to edit single line text
    By cjshaw in forum AutoCAD LT - General
    Last Post: 2007-02-14, 04:59 PM
  2. Print mulitiple layouts via the Publish command
    By MPsico in forum AutoCAD Plotting
    Last Post: 2006-12-09, 12:46 AM
  3. PRINT WINDOW & PRINT SETTINGS PER SHEET
    By neb1998 in forum Revit Architecture - Wish List
    Last Post: 2005-07-01, 07:01 PM
  4. Layouts
    By bob.60725 in forum AutoCAD General
    Last Post: 2005-02-18, 08:15 PM
