Please port the remaining applicable tools/commands from 'edit project' work environment to the 'edi
Summary: Please port the remaining applicable Structural pull-down menu categories of create tools over to the family editor work environment. Please also bring across the few remaining applicable tools from the Modify-Geometry category.
Description: Let's bring/port over into the family editor the entire category of creation tools/commands found in the Structure-Structure, Structure-Foundation, Structure-Reinforcement & Structure-Opening menu pull-downs in the standard project work environment.
The applicable tools from the Structure-Model, Structure-Datum & Structure-Work Plane menu pull-downs in the project editor environment have already been ported over to the family editor environment. Why not bring the rest of these Structure menu pull-down commands over as well?
Nearly all of the applicable tools from the Modify menu pull-down from the project editor environment have already been ported across to the Modify menu pull-down in the family editor. But there are a five from the Modify-Geometry pull-down menu which were not. Let's bring those across as well please.
Product and Feature: Revit Structure - Other
Submitted By: Brian Yeo on 11/16/2015
Re: Please port the remaining applicable tools/commands from 'edit project' work environment to the 'edi
Port remaining applicable tools/commands from 'edit project' environ to 'edit family' environ
The applicable tools from the Structure-Model, Structure-Datum & Structure-Work Plane menu pull-downs in the project editor environment have already been ported over to the family editor environment. Let's bring the rest of these Structure menu pull-down commands over as well?
The applicable tools from the Structure-Model, Structure-Datum & Structure-Work Plane menu pull-downs in the project editor environment have already been ported over to the family editor environment. Let's bring the rest of these Structure menu pull-down commands over as well.
Port commands from 'edit project' environ to 'edit family' environ
Nearly all of the applicable tools from the Modify menu pull-down from the project editor environment have already been ported across to the Modify menu pull-down in the family editor. But there are five from the Modify-Geometry pull-down menu which were not. Let's bring those across as well please.
- You may not post replies
- You may not edit your posts
Forum Rules
