Add Fire Proofing Geometry to Structural Members
Summary: Ability to add geometric fire proofing to steel columns, beams, etc with a button similar to 'Add Insulation' to duct pipe.
Description: Using a similar workflow as adding insulation to Duct or Pipe, when select a structural member a contextual button would appear on ribbon allowing option to 'Add Fire Proofing' just the same way insulation is added to mechanical systems. A type selector would be included so various thicknesses could be saved in the project.
Also and edit insulation button and remove insulation button on the same contextual ribbon tab.
Product and Feature: Revit Structure - Structural Family Contents/Components
Submitted By: Nick Tanner on 11/16/2015
- You may not post replies
- You may not edit your posts
Forum Rules
