Can someone please help me out? what the largest rendering Revit will do? i need a rendering that is 123" wide at 150dpi, but all i get is it going 100% rendered within seconds and a black screen
Part of that depends on your workstation and part of that depends on how you are rendering.
For something very large you may want to consider sending it to the A360 Cloud.
I believe there's no limitation on how big revit will render, but I know there are system limitations.
I've run out of 32gb of ram before trying to render.
iRay will only render up to 2GB, but revit isn't on that yet.
How tall is your rendering?
One option to try is to create a new model, draw 4 walls with a material (say brick) and render it to that size.
See if it works.
I'm guessing that either the scene is to complex for you system or you've got a lot of stuff on that doesn't need to be.
Just a thought.
