Results 1 to 10 of 12
Thread: Automatic publish lisp needed
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default Automatic publish lisp needed
    Hello everyone,
    I'm looking for a lisp that will run the save and automatic publish to a PDF file only will I type in the command 'APS'.
    Thanks,
    Caddl4a
    5,719
    Default Re: Automatic publish lisp needed
    Why not just use the Autopublish mechanism?
    2001-12
    Newport Beach, CA
    399
    Sorry, what is the Autopublish mechanism? If you mean the autopublish setting under the plot and publish tab in the option setting, I don't want this to happen each time. Just on select files when needed.
    Thanks,
    Cadd4la
    5,719
    You and share the same mindset with regard to Autopublish - which is why I developed this, in order to allow me to specify which drawings or directories were 'allowed', and anything that didn't match would be 'vetoed'.
    In any event, sounds like you'd be able to get away with a simple macro (or LISP) that employs SAVE and EXPORTPDF Commands.
    Cheers
    2001-12
    Newport Beach, CA
    399
    For want I can tell from the description of your program it's not going to meet my needs. I want to have the able to save to a pdf only for example, 1 out of 3 times, not every time that one file is saved.
    Thanks,
    5,719
    Did you consider the latter part of my post, unrelated to the app?
    Besides, I do not use Autopublish for everything either, and simply toggle it on/off as needed; the app simply makes it easier to work with when enabled.
    http://forums.augi.com/showthread.ph...=1#post1294398
    Cheers
    2001-12
    Newport Beach, CA
    399
    Thanks, for the code.
    Now, I got to figure out how to have your code run, then do a save and then run your code again to turn off Autopublish.
    2003-07
    561
    2001-12
    Newport Beach, CA
    399
    Thanks,
    I will look into the link.
    5,719
    Quote Originally Posted by cadd4la View Post
    (defun c:SavePlot (/ *error* automaticpub)
      (defun *error* (msg)
        (if automaticpub
          (setvar 'automaticpub automaticpub)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
      (if
        (and
          (setq automaticpub (getvar 'automaticpub))
          (setvar 'automaticpub 1)
         (command "._qsave")
      (*error* nil)
  1. Help needed with Lisp
    By Tharwat in forum AutoLISP
    Last Post: 2010-07-17, 12:30 AM
  2. Replies: 12
    Last Post: 2010-01-08, 07:49 PM
  3. Automatic Publish
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2008-03-14, 02:00 PM
  4. Automatic hyperlink through lisp?
    By Mr Cory in forum AutoLISP
    Last Post: 2007-03-22, 10:41 PM
