I'm working on a BIM project with 3D models extracted from REVIT. How I get Object Enablers so I can see 3D model components in AutoCAD 2016?
How are the 3D models being "extracted" from Revit? If you are exporting a Revit 3D view to AutoCAD, you should get a DWG file that has native AutoCAD objects (polyface meshes, block references containing polyface meshes) that can be seen in AutoCAD without the need for an object enabler.
