I try to add Text object at the same point with Block object.
But it gave an error at red line below.
Error Code is;
Run-time error '5':
Invalid prosedure call or argument
Sub Block_Attributes_to_Text()
Dim obj As AcadBlockReference
Dim oText As AcadText
Dim inspt As Variant
Dim AttList As Variant
Dim metin As String
Dim poz As String
Dim adet As String
Dim cap As String
Dim ara As String
Dim boy As String
Dim MidPoint(0 To 2)
Dim NewColorObject As AcadAcCmColor
Dim acı As Double
ThisDrawing.Utility.GetEntity obj, inspt, "Select Block:"
If obj.ObjectName = "AcDbBlockReference" Then
If obj.HasAttributes Then
AttList = obj.GetAttributes
For i = LBound(AttList) To UBound(AttList)
Select Case AttList(i).TagString
Case Is = "POZ1"
poz = AttList(i).TextString
Case Is = "DAD"
adet = AttList(i).TextString
Case Is = "CAP"
cap = AttList(i).TextString
Case Is = "ARA"
ara = AttList(i).TextString
Case Is = "BOY1"
boy = AttList(i).TextString
End Select
Next i
End If
Else
MsgBox "You did not select a block."
End If
metin = poz & "+" & adet & "»" & cap & "/" & ara & " L=" & boy
MidPoint(0) = obj.InsertionPoint(0)
MidPoint(1) = obj.InsertionPoint(1)
MidPoint(2) = 0
Set oText = ThisDrawing.ModelSpace.AddText(metin, MidPoint, 5)
Set NewColorObject = obj.TrueColor
NewColorObject.ColorMethod = acColorMethodByACI
NewColorObject.ColorIndex = 2
oText.TrueColor = NewColorObject
acı = obj.Rotation
oText.Rotate MidPoint, acı
oText.Update
acı = Empty
Set NewColorObject = Nothing
Erase MidPoint
boy = vbNullString
ara = vbNullString
cap = vbNullString
adet = vbNullString
poz = vbNullString
metin = vbNullString
AttList = Empty
inspt = Empty
oText = Nothing
obj = Nothing
End Sub
