Results 1 to 7 of 7
Thread: Revit viewer
    2016-01
    DE, MD, PA
    16
    Question Revit viewer
    Is a360 viewer a viable revit model viewer? PMs need something to view models but don't want to waste a seat on them...
    2016-02
    Madison, WI
    61
    Default Re: Revit viewer
    Are talking about floor plans or the ability to walk around in the model? I would look at giving them Naviswork Freedom. All PM's and field staff in our office use it. Now this cant open a native rvt file but instead a nwd file. Your office would have to get in the practice of creating nwd's in Navisworks Simulate or Manage. I don't like to have my users logging in every time they want to view the model and most the time the internet connection on site is spotty at best so A360 just isn't a good solution for us. Another thing with A360 is large models in the viewer just chug.
    2003-03
    Philadelphia, PA
    2,392
    Quote Originally Posted by DougBIM View Post
    A "Revit Viewer 20xx" shortcut should appear under the Start > All Programs > Autodesk > Revit 20xx. If your PMs start with that, they will be in viewer mode and will not pull a license (if you have network licenses). If you do not have network licenses, I am not sure if you can install Revit with just the viewer option, although if you do so and do not activate it, you would get a 30-day trial after which it would work in viewer mode.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Quote Originally Posted by dkoch View Post
    I'm probably mistaken, but I thought Revit was a viewer if not licensed.
    2016-01
    DE, MD, PA
    16
    We have standalone licenses. I know the "viewer" is installed when you install Revit, but didn't see a separate install for just the viewer. I will look into downloading maybe a trial and see if i can just use it as a viewer as Opie mentioned. Thanks!
    2002-01
    jUSt Here (a lot)
    9,103
    Don't take my word for it. I have rarely used Revit. I just thought I remember there was a note stating that it was a viewer the last time installing it. I could be completely mistaken.
    I could stop if I wanted to hugh.69031's Avatar
    2016-01
    Melbourne, Australia
    360
    Add /viewer to the command you use to run Revit. Here's an example:
    "C:\Program Files\Autodesk\Revit Architecture 2016\Revit.exe" /viewer /language ENU
  1. Revit Viewer Export to DWG
    By OCD in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-05-13, 08:41 PM
  2. Revit Viewer
    By footbridge in forum Software
    Last Post: 2008-05-15, 01:33 AM
  3. Is there a viewer for Revit?
    By CADMama in forum Revit Architecture - General
    Last Post: 2006-07-07, 04:35 PM
  4. Revit viewer
    By Wagurto in forum Revit Architecture - General
    Last Post: 2005-04-07, 03:50 PM
  5. Is there a Revit 3d Viewer?
    By sjsl in forum Revit Architecture - General
    Last Post: 2004-06-25, 09:06 AM
