Why not a dcl list to select from this one is from Alan J Thompson the calling code is
(if (not AT:listselect )(load "listselect"))
(AT:ListSelect title label height width multi lst)
the lst being just that your list to pick from, just check the answer returned for say "ADD" then add to lst and rerun again.
;; List Select Dialog (Temp DCL list box selection, based on provided list)
;; title - list box title
;; label - label for list box
;; height - height of box
;; width - width of box
;; multi - selection method ["true": multiple, "false": single]
;; lst - list of strings to place in list box
;; Alan J. Thompson, 09.23.08 / 05.17.10 (rewrite)
(defun AT:ListSelect (title label height width multi lst / fn fo d f)
(setq fo (open (setq fn (vl-filename-mktemp "" "" ".dcl")) "w"))
(foreach x (list (strcat "list_select : dialog { label = \"" title "\"; spacer;")
(strcat ": list_box { label = \"" label "\";" "key = \"lst\";")
(strcat "allow_accept = true; height = " (vl-princ-to-string height) ";")
(strcat "width = " (vl-princ-to-string width) ";")
(strcat "multiple_select = " multi "; } spacer; ok_cancel; }")
(write-line x fo)
(close fo)
(new_dialog "list_select" (setq d (load_dialog fn)))
(start_list "lst")
(mapcar (function add_list) lst)
(end_list)
(setq item (set_tile "lst" "0"))
(action_tile "lst" "(setq item $value)")
(setq f (start_dialog))
(unload_dialog d)
(vl-file-delete fn)
(if (= f 1)
((lambda (s / i s l)
(while (setq i (vl-string-search " " s))
(setq l (cons (nth (atoi (substr s 1 i)) lst) l))
(setq s (substr s (+ 2 i)))
(reverse (cons (nth (atoi s) lst) l))
item
