Hi!
I have a problem in selecting blocks by offseted 0.5m. seleted polyline's coordinates.
My code & drawing is attached herewith.
Avinash
Hi!
Avinash
Dim sset As AcadSelectionSet
Dim scount As Integer
Dim fdata(0 To 1) As Integer
Dim fval(0 To 1) As String
fdata(0) = 0
fval(0) = "INSERT"
fdata(1) = 2
fval(1) = "POINTBLK"
sset.SelectByPolygon(AcSelect.acSelectionSetCrossingPolygon, paray, [fdata], [fval])
no object is selected from above code
Are there any objects within the selection area? Are they on screen at the time of selection. (I'm not certain that is a requirement when using .NET.) Where and how is paray defined and assigned values?
Hi!
I have used instead of
Dim Fdata(0 To 1) As Short
Dim Fval(0 To 1) As Object
Fdata(0) = 0 : Fval(0) = "INSERT"
Fdata(1) = 2 : Fval(1) = "POINTBLK"
and works great
