Thread: problem in Selection Set Crossing Polygon
    2011-08
    Vadodara, India
    147
    Post problem in Selection Set Crossing Polygon
    Hi!
    I have a problem in selecting blocks by offseted 0.5m. seleted polyline's coordinates.
    My code & drawing is attached herewith.
    Avinash
    2011-08
    Vadodara, India
    147
    Default Re: problem in Selection Set Crossing Polygon
    Dim sset As AcadSelectionSet
    Dim scount As Integer
    Dim fdata(0 To 1) As Integer
    Dim fval(0 To 1) As String
    fdata(0) = 0
    fval(0) = "INSERT"
    fdata(1) = 2
    fval(1) = "POINTBLK"
    sset.SelectByPolygon(AcSelect.acSelectionSetCrossingPolygon, paray, [fdata], [fval])
    no object is selected from above code
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Are there any objects within the selection area? Are they on screen at the time of selection. (I'm not certain that is a requirement when using .NET.) Where and how is paray defined and assigned values?
    2011-08
    Vadodara, India
    147
    Hi!
    I have used instead of
    Dim Fdata(0 To 1) As Short
    Dim Fval(0 To 1) As Object
    Fdata(0) = 0 : Fval(0) = "INSERT"
    Fdata(1) = 2 : Fval(1) = "POINTBLK"
    and works great
  1. RE: Dynamic Blocks using a crossing polygon for linear stretch
    By HFRdetailing in forum Dynamic Blocks - Technical
    Last Post: 2011-06-28, 01:28 PM
  2. Crossing selection box not appearing
    By mpfprjo0890 in forum AutoCAD General
    Last Post: 2011-06-23, 07:22 PM
  3. Crossing Polygon in SSGET statement
    By caddog71 in forum AutoLISP
    Last Post: 2010-03-18, 07:45 PM
  4. Crossing Polygon gone!
    By Merlin in forum AutoCAD General
    Last Post: 2005-11-11, 07:37 AM
  5. Selection by 'Window' or 'Crossing'
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2005-04-29, 10:07 PM
