Hello,
I'm having some trouble with some results of my Model Review and I'm hoping somewhere out there can explain something...
I've run a model review and it is telling me that a good quantity of my floor slabs are outside the defined range set in the check. but they're actually not... as far as I can tell?
My check is set to look for slabs outside the range of 0.1m and 0.6m (100mm-600mm) but it keeps picking up slabs within this range and labeling them as "Value not set correctly".
I can't figure out what it means by "Value not set correctly". As far as I can tell, there is nothing wrong with the slabs. I have the check set to filter out anything that has had modifications made to the thickness (sloping etc.) so it should only pick up non-modified slabs outside the range. But it doesn't.
I've attached a screenshot of the HTML file so you can take a look if you like.
