Thread: Update Serial Number - Network License
    2008-04
    LA area
    147
    Default Update Serial Number - Network License
    Greetings,
    We have a new network license file that will be swapped in a few days from now. The serial numbers for perpetual licenses have changed.
    Questions:
    1. After the new license file is active, will the existing installs of BDS applications update their serials based on the new license file they find on FlexLM?
    2. If not, whats the protocol for updating the serial number stored in the application?
    I seem to remember once upon a time the answer to question #1 was yes. Only info I'm finding on the interwebs are for Stand-alone serial changes.
    Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Update Serial Number - Network License
    You may need to contact your reseller for this answer.
    2012-07
    Illinois
    2
    For network licensed products, the serial number on the client is irrelevant. If you change the licensing on the NLM server, it will still work for the client without any additional changes. You should be just fine moving forward.
  1. 2011 - Serial Number?
    By saeborne in forum Revit Architecture - General
    Last Post: 2010-04-16, 08:04 PM
  2. How to Update Serial Number in RAC 2010 Like in Autocad 2010
    By bingles7 in forum Revit Architecture - General
    Last Post: 2009-11-22, 05:06 PM
  3. vba serial number check
    By jbortoli in forum VBA/COM Interop
    Last Post: 2008-07-08, 08:13 PM
  4. Serial number error
    By tarch in forum Revit Architecture - General
    Last Post: 2007-06-26, 11:20 PM
  5. Receiving of serial number for R6
    By Gerhard in forum Revit Architecture - General
    Last Post: 2004-01-20, 11:31 PM
Tags for this Thread
