I've tried a few searches, but I'm not sure of the best wording to use for this question.
I guess it's basically, is there (or will there be) a way to assign a view to text, much like one would do for a callout or section mark that refers to an existing detail? For instance, if I want to refer to a particular view in a note or in a text block on a sheet, normally I would either just type in the detail/page reference or somehow insert an independent tag or custom section mark (text only, without the graphic) into a gap in the text. Both of these are problematic: the former because it often gets missed in the event the detail is moved or taken off the sheet, the latter because changes to the text block often throw it out of whack (misaligned with the text or completely in the wrong part of the sheet).
I'm basically assuming this feature doesn't exist. If it does not, has this feature been requested before? Has anyone found a better way than how I describe above?
