That definitely solved my problem.
Thanks.
-Teresa
Hi, I played around with this a little and I think I have something that will work. I used a rotation parameter and rotation action, a linear parameter with a move action, and then a block properties table to correlate the linear move values at 90 degree rotation increments. See attached file.
Was there something lacking in the solution I posted a couple weeks ago in this thread: http://forums.autodesk.com/t5/dynami...e/td-p/6009061 ?
I saw this post listed with no replies, no link to a solution and was listed it as their first and only post.
I meant no disrespect to you or your solution. I didn't even know it existed.
No worries. My post wasn't directed to you. Your post and solution are spot on. The only difference between the two is that I used a double lookup as opposed to your block properties. I was just a little perplexed to see the OP post the same question on this forum a week after I posted the solution on the Autodesk forum.
