Recently l have tried to remove some line items from my Options Menu.
The process use to be very simple in versions before 2016.
You would click on the line you wanted to remove, hit the remove button and hit Apply.
The line item was removed, and DID NOT TO SHOW UP AGAIN.
For some reason, in 2016, no matter how often I remove an item it come back the next day, or next time I start AutoCAD.
Has anyone else had this problem?
Is their a work around?
AutoCAD if your monitoring, why are you forcing the program to keep re-loading something I've told it to remove?
Thanks everyone and anyone in advance for any suggestions, help, etc.....
