Hi, i just bought Nvidia videocard that autodesk certified quadro K600, and i tried installing all kind of drivers even new ones and old ones, certified ones.. in 3DCONFIG it still shows up as: Your machine contains a 3D Device that is not certified.
here is the driver that autodesk listed but it doesnt work:
my system:
16gb of ram
win7 64bit
i5
CPU-Z TXT Report
Binaries
CPU-Z version 1.70.0.x64
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.125 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 3470
Codename Ivy Bridge
Specification Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping N0
Technology 22 nm
TDP Limit 77 Watts
Tjmax 105.0 °C
Core Speed 1699.6 MHz
Multiplier x Bus Speed 17.0 x 100.0 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 36x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins +4
Ratio 1 core 36x
Ratio 2 cores 36x
Ratio 3 cores 35x
Ratio 4 cores 34x
TSC 3200.1 MHz
APERF 3420.4 MHz
MPERF 3144.7 MHz
Chipset
Northbridge Intel Ivy Bridge rev. 09
Southbridge Intel H77 rev. 04
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16 GBytes
Channels Dual
Memory Frequency 666.5 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Kingston (7F980000000000000000)
Size 8192 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number KHX1600C10D3/8GX
Serial number 72253903
Manufacturing date Week 38/Year 13
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.3
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.500 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 10.0
Min tRP 12.50 ns
Min tRCD 12.50 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-7-7-17-22-n.a @ 480 MHz (1.500 Volts)
XMP #2 7.0-7-7-19-26-n.a @ 560 MHz (1.500 Volts)
XMP #3 8.0-8-8-22-29-n.a @ 640 MHz (1.500 Volts)
XMP #4 9.0-9-9-25-33-n.a @ 720 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Serial number 78256003
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 10.0
Min tRP 12.50 ns
Min tRCD 12.50 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Please help me with this problem..
I tried it on autocad 2012 LT 2013LT and 2014LT
Here is the tuner log:
Performance Tuner Results Log
Version: 19.0.2.00
Date of Last Tune: 2016.02.02.
Machine Configuration
Processor Speed : 3.2 GHz
RAM : 16327 MB
3D Device
Name : NVIDIA Quadro K600
Manufacturer : NVIDIA
Chip set : Quadro K600
Memory : 688 MB
Driver : 9.18.0013.4052
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: acaddm10.hdi
Current Effect Status:
Enhanced 3D Performance: Available and on
Smooth display: Not available
Gooch shader: Software emulation in use
Per-pixel lighting: Not available
Full-shadow display: Not available
Texture compression: Not available
Advanced material effects: Not available
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
