Thread: AutoCad 2012, 2013, 2014 LT device not certified quadro K600
    2015-06
    4
    Default AutoCad 2012, 2013, 2014 LT device not certified quadro K600
    Hi, i just bought Nvidia videocard that autodesk certified quadro K600, and i tried installing all kind of drivers even new ones and old ones, certified ones.. in 3DCONFIG it still shows up as: Your machine contains a 3D Device that is not certified.
    here is the driver that autodesk listed but it doesnt work:
    my system:
    16gb of ram
    win7 64bit
    i5
    CPU-Z TXT Report
    Binaries
    CPU-Z version			1.70.0.x64
    Processors
    Number of processors		1
    Number of threads		4
    APICs
    Processor 0
    	-- Core 0
    		-- Thread 0	0
    	-- Core 1
    		-- Thread 0	2
    	-- Core 2
    		-- Thread 0	4
    	-- Core 3
    		-- Thread 0	6
    Timers
    	ACPI timer		3.580 MHz
    	HPET timer		14.318 MHz
    	Perf timer		3.125 MHz
    	Sys timer		1.000 KHz
    Processors Information
    Processor 1			ID = 0
    	Number of cores		4 (max 8)
    	Number of threads	4 (max 16)
    	Name			Intel Core i5 3470
    	Codename		Ivy Bridge
    	Specification		Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
    	Package (platform ID)	Socket 1155 LGA (0x1)
    	CPUID			6.A.9
    	Extended CPUID		6.3A
    	Core Stepping		N0
    	Technology		22 nm
    	TDP Limit		77 Watts
    	Tjmax			105.0 °C
    	Core Speed		1699.6 MHz
    	Multiplier x Bus Speed	17.0 x 100.0 MHz
    	Stock frequency		3200 MHz
    	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    	L1 Data cache		4 x 32 KBytes, 8-way set associative, 64-byte line size
    	L1 Instruction cache	4 x 32 KBytes, 8-way set associative, 64-byte line size
    	L2 cache		4 x 256 KBytes, 8-way set associative, 64-byte line size
    	L3 cache		6 MBytes, 12-way set associative, 64-byte line size
    	FID/VID Control		yes
    	Turbo Mode		supported, enabled
    	Max non-turbo ratio	32x
    	Max turbo ratio		36x
    	Max efficiency ratio	16x
    	Min Power		60 Watts
    	O/C bins		+4
    	Ratio 1 core		36x
    	Ratio 2 cores		36x
    	Ratio 3 cores		35x
    	Ratio 4 cores		34x
    	TSC			3200.1 MHz
    	APERF			3420.4 MHz
    	MPERF			3144.7 MHz
    Chipset
    Northbridge			Intel Ivy Bridge rev. 09
    Southbridge			Intel H77 rev. 04
    Graphic Interface		PCI-Express
    PCI-E Link Width		x16
    PCI-E Max Link Width		x16
    Memory Type			DDR3
    Memory Size			16 GBytes
    Channels			Dual
    Memory Frequency		666.5 MHz (1:5)
    CAS# latency (CL)		9.0
    RAS# to CAS# delay (tRCD)	9
    RAS# Precharge (tRP)		9
    Cycle Time (tRAS)		24
    Command Rate (CR)		1T
    MCHBAR I/O Base address		0x0FED10000
    MCHBAR I/O Size			19456
    MCHBAR registers
    Memory SPD
    DIMM #				1
    	SMBus address		0x50
    	Memory type		DDR3
    	Module format		UDIMM
    	Manufacturer (ID)	Kingston (7F980000000000000000)
    	Size			8192 MBytes
    	Max bandwidth		PC3-10700 (667 MHz)
    	Part number		KHX1600C10D3/8GX
    	Serial number		72253903
    	Manufacturing date	Week 38/Year 13
    	Number of banks		8
    	Nominal Voltage		1.50 Volts
    	EPP			no
    	XMP			yes
    	XMP revision		1.3
    	AMP			no
    JEDEC timings table		CL-tRCD-tRP-tRAS-tRC @ frequency
    	JEDEC #1		6.0-6-6-17-23 @ 457 MHz
    	JEDEC #2		7.0-7-7-20-27 @ 533 MHz
    	JEDEC #3		8.0-8-8-22-30 @ 609 MHz
    	JEDEC #4		9.0-9-9-24-33 @ 666 MHz
    XMP profile			XMP-1600
    	Specification		PC3-12800
    	Voltage level		1.500 Volts
    	Min Cycle time		1.250 ns (800 MHz)
    	Max CL			10.0
    	Min tRP			12.50 ns
    	Min tRCD		12.50 ns
    	Min tWR			15.00 ns
    	Min tRAS		33.75 ns
    	Min tRC			45.00 ns
    	Min tRFC		260.00 ns
    	Min tRTP		7.50 ns
    	Min tRRD		6.00 ns
    XMP timings table		CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
    	XMP #1			6.0-7-7-17-22-n.a @ 480 MHz (1.500 Volts)
    	XMP #2			7.0-7-7-19-26-n.a @ 560 MHz (1.500 Volts)
    	XMP #3			8.0-8-8-22-29-n.a @ 640 MHz (1.500 Volts)
    	XMP #4			9.0-9-9-25-33-n.a @ 720 MHz (1.500 Volts)
    DIMM #				2
    	SMBus address		0x52
    	Memory type		DDR3
    	Module format		UDIMM
    	Size			8192 MBytes
    	Serial number		78256003
    	Number of banks		8
    	EPP			no
    	XMP			yes
    	XMP revision		1.3
    	AMP			no
    	Max CL			10.0
    	Min tRP			12.50 ns
    	Min tRCD		12.50 ns
    	Min tWR			15.00 ns
    	Min tRAS		33.75 ns
    	Min tRC			45.00 ns
    	Min tRFC		260.00 ns
    	Min tRTP		7.50 ns
    	Min tRRD		6.00 ns
    Please help me with this problem..
    I tried it on autocad 2012 LT 2013LT and 2014LT
    Here is the tuner log:
    Performance Tuner Results Log
    Version: 19.0.2.00
    Date of Last Tune: 2016.02.02.
    Machine Configuration
    Processor Speed  : 3.2 GHz
    RAM              : 16327 MB
    3D Device
    Name             : NVIDIA Quadro K600
    Manufacturer     : NVIDIA
    Chip set         : Quadro K600
    Memory           : 688 MB
    Driver           : 9.18.0013.4052
    As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
    You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
    Current application driver:    acaddm10.hdi
    Current Effect Status:
    Enhanced 3D Performance:   Available and on
    Smooth display:            Not available
    Gooch shader:              Software emulation in use
    Per-pixel lighting:        Not available
    Full-shadow display:       Not available
    Texture compression:       Not available
    Advanced material effects: Not available
    Available application drivers and effect support:
    Software driver
    Effect support:
      Enhanced 3D Performance:   Not applicable
      Smooth display:            Not applicable
      Gooch shader:              Software emulation only
      Per-pixel lighting:        Not applicable
      Full-shadow display:       Not applicable
      Texture compression:       Not applicable
      Advanced material effects: Not applicable
    Autodesk driver:  Not Certified
    Effect support:
    9,805
    Default Re: AutoCad 2012, 2013, 2014 LT device not certified quadro K600
    Might want to try contacting them here.
    2015-06
    4
    Might want to try .
    already did.. no answer..
    2,095
    From what I remember, the list is local to the install i.e. it doesn't check a master list on the internet. So for programs that are several years old it could be listed as uncertified but actually is.
    However, it doesn't really matter if its certified or not. Will it let you turn on hardware acceleration? Does it fail/cause graphics glitches?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by dgorsman View Post
    That is all that matters. Certification is only the result of testing combinations. If your combination hasn't been tested, it isn't certified - it doesn't mean there is anything wrong with it.
    2015-06
    4
    I have another machine with autocad 2016 LT and K620 quadro card and the card shows as certified and the effects of smoothing and etc are avaliable and visible, but on this machine with autocad 2012/2013 LT and quadro k600 it doesnt shows as certified and effects are not avaliable.
    No glitches, autocad doesnt even use videocard to proccess anything..
    Autodesk support is not supporting 
    Anyone has any idea ?
  1. 2014: AutoCAD Architecture 2012 and 2014 coordination
    By lisa.149109 in forum ACA General
    Last Post: 2014-05-27, 04:53 AM
  2. 2013: Revit 2012 can export RVT to DGN but not in 2013/2014
    By SunYog in forum Revit Architecture - General
    Last Post: 2014-02-13, 11:06 AM
  3. 2013: Autosave & Multileader text in 2012, 2013 & 2014
    By sovby254640 in forum AutoCAD Annotation
    Last Post: 2013-12-04, 05:01 PM
  4. Replies: 3
    Last Post: 2013-11-23, 01:58 AM
  5. Install/unistall AutoCAD 2014-2012
    By AcadDurango in forum AutoCAD General
    Last Post: 2013-06-11, 02:55 PM
