Thread: Corridor Event Viewer
    2009-11
    Raleigh, NC
    944
    Default Corridor Event Viewer
    Is there a way to suppress the event viewer box from popping up every time I make a revision to my Corridor model?
    2016-01
    15
    Default Re: Corridor Event Viewer
    https://forums.autodesk.com/t5/autoc...1751453#M26666
    "go to the settings tab of prospector, right click on your
    drawing name, select Edit Drawing Settings. The last tab in the
    resulting dialog box is the Ambient Settings tab. The first group is
    general there, expand that and select NO for show event viewer.
    Do this in your drawing template if you want to turn it off forever -
    it's a drawing-specific setting.
    Jason Hickey"
    2009-11
    Raleigh, NC
    944
    Awesome, Thank you,
    Earth
    9,805
    I usually make mine really small and tuck it in the lower right hand corner of my second or third monitor, then if I DO need to see something in there, it's available and I can expand it.
    Of course I guess you can just use the SHOWEVENTVIEWER command to make it appear too.
    R.K. McSwain | CAD Panacea |
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    I keep mine set to auto-hide and tucked away in the corner. That way in doesn't open every time a message is displayed but is readily available when I need it.
  1. 2014: Event Viewer Error Message When Rebuilding Corridor
    By FBL - Desirea in forum AutoCAD Civil 3D - Corridors
    Last Post: 2013-11-06, 09:07 PM
  2. 2012: Data Shortcuts and Event Viewer Errors
    By eric.schey in forum AutoCAD Civil 3D - General
    Last Post: 2013-01-28, 04:51 PM
  3. Event Viewer
    By clarkl in forum AutoCAD Civil 3D - General
    Last Post: 2011-11-04, 03:45 PM
  4. corridor section viewer
    By bpizana in forum AutoCAD Civil 3D - Corridors
    Last Post: 2011-06-13, 12:06 PM
  5. Station Equations and the Corridor Section Viewer
    By joseph.holzwart in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-02-21, 12:53 AM
