Issue:
When using Baseline Dimensions in Dependent Views, Spacebar flipping is disabled and the handles to move text are located at the Project Base Point when the PBP is outside the Crop region. (see attached) Dependent View & Baseline Demension Issue.pdf
Conclusion:
Opening the Parent View restores flipping and dragging to the default behavior, even if the Parent View is not the active view. Close the Parent and functionality is again lost.
WTFMF?
Seems like an odd quirk and a reason for this behavior to be as intended eludes me.
Perhaps since I usually annotate in the Parent this has not been much of an issue before. Surprised to not find any threads on this out there, maybe my search criteria is poor.
Any thoughts?
I'd be interested in other workarounds or insight to effect the behavior.
Cheers.
