Does anyone know how I can remove an old printer from the name drop down list in the print dialog of Revit?
Uninstall the printer from your computer.
That should remove it from all printer lists in all programs. If it's not installed, it cannot be used.
You really should provide more information.
Have you restarted the computer?
Does the plotter show up in other programs?
Have you verified that it was removed from the computer by going to the Devices and Printers section in control panel?
Thanks for your input.
That's why this is perplexing.
YesHave you restarted the computer?
YesDoes the plotter show up in other programs?
YesHave you verified that it was removed from the computer by going to the Devices and Printers section in control panel?
Is it possible that you have a Printer Setup saved that address that old printer?
That was a good idea, bu no there aren't any printer setups besides the default. However I do now see that the printer in question has a status of "Pending deletion: 3 documents waiting". I must've tried to print with it, the print jobs failed, so I deleted the printer. Anyone know where can I purge these pending printing jobs?
My first thought is a temp folder.
You need to stop and start the print service and clear the print spool.
http://www.online-tech-tips.com/comp...a-print-queue/
